ASA5510 + AnyConnect trouble
Dec 10th, 2007
Can't get it to work log says:Syslog ID: 716023 Group <DfltGrpPolicy> User <wmdata> IP <217.xx.xx.xx> Session could not be established: session limit of 2 reached.
And license tab says "Clientless SSL VPN Peers: 2 "
But active VPN Tunnels is 0 on all.
So where is the license gone ?
Jason Gervia Mon, 12/10/2007 - 11:15
  • Cisco Employee,
Nordintom,
This is a bug in 8.0(2) that is fixed in 8.0(3). It will also resolve itself if you reboot the firewall.
I'll post the bugID when I find it.
nordintom Thu, 12/13/2007 - 23:33
Thanks Jagervia, upgrade to 8.0(3) solved the problem.
