Guest Tunneling Problems
Answered Question
Dec 10th, 2007
I was wondering if anybody could help me out here. I have been following the guidelines as per the WLC softweare configuration guide with regards to configuring the internal controller which is pretty straightforward. The mobility anchor is up with the DMZ controller however I am not sure what configuration is required on the DMZ controller itself with regards to DHCP and the Guest WLAN itself. To be honest the documentation is a bit skimpy to say the least.
Any help would be greatly appreciated
Cheers,
Martin
Correct Answer by wiluszm about 9 years 1 month ago
Martin,
I share your frustrations with the documentation on the guest access. From what you stated you're having trouble with how guest access mobility is configured with respect to DHCP. Hope this helps.
The first part is well documented. Setup a mobility group between the remote and DMZ controller. Make sure it's up. Now we'll move onto DHCP configuration.
1) On the DMZ controller, configure a DHCP pool for the guest clients. Make sure you build a WLAN and bind it to the proper interface
2) On the remote controller, under your "management" interface set the DHCP server to be the ip address of the management interface on the DMZ controller. Very important!
3) Build the guest WLAN on the remote controller with the same configuration and bind it's interface to the management interface of the remote controller.
Voila... all DHCP requests will now be forwarded to the DMZ anchor.
Anything else I can help with let me know.
-Mike
http://cs-mars.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
wiluszm Wed, 12/12/2007 - 10:11
Martin,
-Mike
martinhayes Thu, 12/13/2007 - 02:21
Hi Mike
Thanks for the help. Much appreciated. We've got it working now thankfully but to say it is a dark art is an understatement :)
Happy Christmas
Cheers,
Martin
Trending Topics - Security & Network
