ISDN log messages
Dec 10th, 2007
hi,
I am seeing following log messages in my 1721 router. Can anybody tell me how to stop this or this is normal..
Dec 10 12:19:35.270: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 102 change
d to up
Dec 10 12:19:45.298: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 102 chan
ged to down
Dec 10 12:54:29.613: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 87 changed
to up
Dec 10 12:54:39.629: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 87 chang
ed to down
Dec 10 13:29:23.285: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 80 changed
to up
Dec 10 13:29:33.365: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 80 chang
ed to down
Dec 10 14:04:23.681: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 81 changed
to up
Dec 10 14:04:33.701: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 81 chang
ed to down
shiva_ial Mon, 12/10/2007 - 06:27
hi sagar,
the output shows there is frequent changes in layer 2 status of isdn
if you put sh isdn status command it will
show your isdn layer 2 status along with layer1&3
two options available in layer 2
multiframe estabilsed -means circuit is up till telco (your service provider)
tei_unassigned - means probelm connecting to your telco (your service provider)
to disable log use
no logging buffered command
rgds
shiva
rate it if it helps
sagar.shetty Mon, 12/10/2007 - 07:15
Hi Shiva,
Thanks for your info... Actually, my isdn is a backup for a dedicated link which is currently up but still I am seeing these messages... Any idea, what could be this issue,...
Richard Burts Mon, 12/10/2007 - 08:18
Sagar
The logs indicate that the ISDN is coming up at various time intervals and is staying up for 10 seconds. It looks to me like something is making calls on the ISDN that last 10 seconds. If you run debug dialer through several of these occurances and post the output it might show us what is causing the ISDN to activate. It might also be helpful to see the output of debug isdn q931.
Rick
sagar.shetty Tue, 12/11/2007 - 21:38
Hi Rick,
I tried the debugging commands but couldnot find any messages even the log showed only the above messages..
smothuku Tue, 12/11/2007 - 22:15
Hi Sagar ,
Would like to know that whether the isdn is active link or standby link .
Can you send us the config of both the routers.
Can you send us "show isdn active" , show isdn status and show isdn his outputs.
satish
sagar.shetty Tue, 12/11/2007 - 22:40
Here's the ISDN config and the sh isdn o/p
interface BRI0
bandwidth 128
no ip address
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
load-interval 30
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
no fair-queue
no cdp enable
ppp authentication chap
ppp multilink
end
interface Dialer0
ip address X.X.X.X
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool 1
dialer remote-name abcd
dialer string 123456
dialer load-threshold 125 outbound
dialer-group 1
no cdp enable
ppp multilink
dialer-list 1 protocol ip permit
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
ISDN CALL HISTORY
Call History contains all active calls, and a maximum of 100 inactive calls.
Inactive call data will be retained for a maximum of 15 minutes.
Also, to inform you, the ISDN is a backup for a serial link and it will get fired when the primary link goes down..
smothuku Wed, 12/12/2007 - 00:42
Hi Sagar ,
Every thing looks fine..Below is the config of isan , which is backup for serial link.Please check it step by step and let me know if you miss something.
Router A:
username admin password cisco
Interface s0
ip add x.x.x.x
back delay 5 120
backup interface bri0
interface BRI0
bandwidth 128
encapsulation ppp
PPP chap hostname Router A hostname
ppp multilink
end
interface Dialer0
ip address X.X.X.X
encapsulation ppp
dialer pool 1
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp chap hostname "outer A hostname"
ppp multilink
router B :
interface BRI0
bandwidth 128
encapsulation ppp
PPP chap hostname "Ruter Bhostname"
ppp multilink
end
interface Dialer0
ip address X.X.X.X
encapsulation ppp
dialer pool 1
dialer remote-name xxxx
dialer caller Router A number
dialer-group 1
no cdp enable
ppp multilink
In the above config , call is connecting from Router A to Router B.
Remove backup interface command from serial and check the isdn status.
After that put the command under serial interface.
Please check the below link.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a00800b1148.shtml
satish
sagar.shetty Wed, 12/12/2007 - 04:16
Hi Satish,
Thanks for you information...
Things look to be fine from the config pespective. But for the backup, I am using floating static route. Could that be the reason for this...
smothuku Wed, 12/12/2007 - 05:02
Hi Sagar ,
No , it doesn't matter.We should have floating static route to forward the traffic in case of primary link fail.
If possible send me both the routers config.
Restart the NT boxes on both ends and check it.
satish
