RME: configurations management
Dec 10th, 2007
Hello all,
My customer want to created its own configurations and put them in the right directory (maybe shadow directory ??) I would like to push them all with a script, just with one action (not with config editor which means to push them one by one ...)
Is it possible? with scripting in perl
ccbootcamp Mon, 12/10/2007 - 08:28
There are programs out there that will do that.
But, sure it's possible to do it with perl.
IMHO, Best way would be with TCL "aka tickle" scripting. I use TCL scripting all the time to do misc. things.
(please rate the post if this helps!)
Joe Clarke Mon, 12/10/2007 - 15:11
You can script the cwcli command to do this kind of thing. For example, to push an arbitrary config file onto a device:
cwcli config import -u admin -p admin -f /tmp/device.cfg -device
There are more advanced options for bulk config operations. See the cwcli documentation in RME.
