SQL database - where to find phone config
Dec 10th, 2007
In CCM 4.1.3 I am trying to see if their is a SQL database that will show the phone config.
I can see in the Device database those phone that have a 7914 attached, I now need to find a table that shows how those keys are configured ie as lines or speed dials and any associated DN's
I am trying to find a way to determine that if an extn has a 7914 does the user really need it or can someone else have to save buying new ones all the time.
andym1iptech Tue, 12/11/2007 - 00:52
Gonzalo
Thanks for the reply, they are certainly useful queries to be able to run.
However it doesnt give me the results I am after.
If a phone has a 7914 attached to it and is configured for, lets say, 15 lines in total I need to run a query that will show that line 1 has extn 1234 configured, line 2 has extn 2345 configured, line 3 is blank, line 4 has 4567 configured,etc etc.
Then I will be able to see that if an extn has 15 lines on it but only 6 have anything configured on them I can take the 7914 from that user as they no longer need it.
Thanks for your help
