Polarity & Diversity for external antennae 1020-1030 Aps
Dec 10th, 2007
Ok,
On an areonet AP, the rp-tnc connectors are
parallel to each other, allowing for the ability to run diversity with dipole antennae, duckies for example.
What if I wanted to do the same on a 1020 AP? Are the external connectors mounted in such a way that it allows for the antennae to be used for diversity? as a dipole setup?
irisrios Mon, 12/17/2007 - 12:57
Yes connectors support diversity antennas on 1020 model . AIR-ANT2012 diversity patch antenna, AIR-ANT5959 diversity omni
are supported.
ericgarnel Tue, 12/18/2007 - 07:07
I guess I should have been more clear. If I wanted to mount a duck antenna on each side, mounted straight out, would they be at 180 out of phase, or would I need to bend them 90?
The reason I ask is that there is a 1020 mounted sideways, thus the polarity of the internal antennae is horizontal. I was thinking of placing ducks on the external mounts for the time being.
We will be replacing most of the 1000 series radios with 1252s in the near future
Trending Topics - Security & Network
