2811 Flash Memory
mchiaravalle_2
I know the corporate answer on this but I thought I'd toss this out. Has anyone used non-Cisco flash in any of the 2800 series routers before? I'm using 2811s for my remote site access routers and I want to upgrade the flash to 128MB
I realize that if I contact TAC they may not support.
I'm finding it hard to spend $500-$700 for a 128MB CF when I can get the best name brand for less than 1/5 the cost.
We use 3rd party CF all the time for upgrades. Very little issues if any - no more issues than with the Cisco branded CF!
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
8 Replies 8
JORGE RODRIGUEZ
Level 10
Level 10
I check with our cisco vendor provider, you may find new MEM2800-128CF cisco compatible for as low as $200.
http://www.dexon.com is an authorized cisco reseller, I have been buying cisco from them for about 6 years and have had no complains. In addition, they provide one year warranty
for any cisco equipement.
Jorge
Jorge Rodriguez
ccbootcamp
Level 7
Level 7
Just send an email to Jason at computer parts now:
jason@computerpartsnow.com
He has the best memory pricing around.
or go to:
http://www.memoryx.net/ci28rorflme1.html
128MB CF flash for $50.
-brad
www.ccbootcamp.com
indeed $50 great price ! can't beat that!
Jorge Rodriguez
2 snaps for that! I remember when 8mb flash for the 2500 series router was $200+/stick! Ah, the good 'ole days.
-brad
www.ccbootcamp.com
OK, thanks.
I was doing some web searching before my original post, that's how I found out about the cheaper alternatives. I was mainly looking for any info on reliability issues.
-brad
www.ccbootcamp.com
Good thanks.
sales
http://simondirect.com/store/index.php?main_page=index&cPath=7_27
MEM2811-256D $96 Cisco Approved
256MB DRAM MODULE Cisco Approved Memory For Cisco Router 2811 MEM2811-256D= MEM2811-256U512D MEM2811-256U512D= MEM2811-256U512D
MAIN CISCO DRAM MEMORY
Maximum Memory: 768mb
Base Memory: 256mb (Non removable)
Upgrade Sockets: 1 (1 bank of 1)
CISCO FLASH MEMORY
Maximum Memory: 256mb
Base Memory: 64mb (Removable)
