Transfer delay 15s
Dec 10th, 2007
<?xml version="1.0"?>
<vxml version="2.1">
Script Pin Caller.
Nov 2007: ver. 1.0
Dec 2007: ver. 1.1
+ Tripple pin check
<var name="default_number" expr="'1224'"/>
<var name="pin_code" expr="5223"/>
<var name="retry_pin" expr="3"/>
<var name="iter_pin" expr="0"/>
<var name="number" expr="''"/>
<var name="my_gtd" expr="new com.cisco.objclass.gtd()" />
<property name="com.cisco.transfer.mode" value="rotary" />
<form id="main">
<block>
<prompt>
<audio expr="'flash:welcome.au'"/>
</prompt>
<goto next="#chk_pin"/>
</block>
</form>
<form id="chk_pin">
<property name="timeout" value="3s"/>
<catch event="noinput"> <goto next="#trans_default"/> </catch>
<block>
<clear namelist="get_pin"/>
<if cond="iter_pin >= retry_pin">
</if>
<assign name="iter_pin" expr="iter_pin + 1"/>
<prompt>
<audio expr="'flash:beep.au'"/>
</prompt>
</block>
<field name="get_pin" type="digits?length=4">
<property name="com.cisco.dtmf.termlength" value="4"/>
<grammar type="application/grammar+regex">[0-9][0-9][0-9][0-9]</grammar>
<filled>
<if cond="get_pin == pin_code">
<goto next="#pin_approve"/>
<else/>
<prompt>
<audio expr="'flash:busy.au'"/>
</prompt>
</if>
</filled>
</field>
</form>
<form id="pin_approve">
<property name="timeout" value="8s"/>
<catch event="noinput"> <goto next="#notmatch"/> </catch>
<block>
<prompt>
<audio expr="'tftp://123.com/vxml/processing.au'"/>
</prompt>
</block>
<field name="num" type="digits?length=4">
<catch event="nomatch">
</catch>
<grammar type="application/grammar+regex">[123][0-9][0-9][0-9]</grammar>
<filled>
<assign name="number" expr="'phone://'+num"/>
<goto next="#trans_number"/>
</filled>
</field>
</form>
<form id="notmatch">
<block>
<prompt>
<audio expr="'flash:goodbye.au'"/>
</prompt>
</block>
</form>
<form id="trans_number">
<block>
<prompt bargein="false">
</prompt>
</block>
<transfer name="mycall" destexpr="number" bridge="false"></transfer>
</form>
<form id="trans_default">
<block>
<audio expr="'flash:no_input.au'"/>
</prompt>
</block>
<transfer name="mycall" destexpr="'phone://'+default_number" bridge="false"> </transfer>
</form>
</vxml>
This is work ok, but between id "pin_approve" and id "trans_number" there is a delay = 15 second. why?
AS5300
