ASDM won't run
Answered Question
Dec 10th, 2007
I just got a new ASA 5510 and upgraded to ASA 8.0 using the ASDM. Then I upgraded the ASDM to 6.0 through the CLI using tftp. They both upgraded and loaded correctly as I can see them both listed when I do a 'sh ver' but nor I cannot connect to the ASDM.
I didn't change the management IP address (it's still 192.168.1.1) and I was able to hit it before the update. Now when I try to access it through a browser I get nothing but 'page cannot be displayed'. Can anyone help me with this?
Correct Answer by husycisco about 9 years 7 months ago
Hi Quantin
You are welcome. Please do not forget to check "resolved authors issue" for the comment.
Overall Rating: 5 (2 ratings)
husycisco Tue, 12/11/2007 - 02:25
  • Gold, 750 points or more
Hi Quinton
Make sure http server enable command exists in config
Also issue the following commands in enable mode and please paste the results here.
dir
sh asdm image
qbakies11 Tue, 12/11/2007 - 06:08
For some reason the 'http server enable' command was not in the config after I upgraded to ASA 8.0 so I added it and am now in the ASDM. Thank you very much for your help.
Correct Answer
husycisco Tue, 12/11/2007 - 06:26
Hi Quantin
