Order of ACLs in PIX config
maileym01
until recently the order of access lists in our PIX config was:
names
acl_outside
acl_dmz
acl_inside
acl nat0
acl crypto maps
static mappings
isakmps
Recently, while editing access-list acl_inside I entered no access-list acl_inside which removed all the acl_inside lines.
I added all these back in but now the order of the access lists has changed and I notice that no rules in acl_inside are been processed as the hit counters are all 0. So I guess no outgoing traffic is being filtered.
The order now is:
names
acl_outside
acl_dmz
acl nat0
acl crypto maps
acl_inside
static mappings
isakmps
How can I revert to the previous order of acls in the pix config?
Why would none of the acl_inside rules now be processed?
Thanks in advance
Marty
mj11
Level 3
Level 3
Hi Marty
The order of the access-list are only applicable within the group I.e acl_inside. Could you make sure you have the ACL aplied to the correct interface in the correct direction, is this causing you problems?
Regards MJ
timkaye
Hello.
My understanding is traffic from the inside to lower security interfaces does not require the access-list and access-group command.
That said removing an entire acl removers the access-group command.
apply
access-group acl_inside in interface inside.
I'm not sure if the same applies for other interfaces wishing to access lower security interfaces.
You can consider yourself lucky :)
Tim
