CCM5.1 BAT Update Phones
Dec 10th, 2007
CallManager System version: 5.1.2.3000-2
I am trying to update many phones at a time using the Bulk tool. I am trying to update the last section on the phone device page that includes options like
PC Port
Settings Access
Web Access
If anyone know of a way please let me know.
Thanks in advance.
Paul
allan.thomas Mon, 12/10/2007 - 15:48
When you refer to 'trying' to update the phones using the BAT tool, do mean that it is failing for you?
You can certainly update the device settings through the BAT tool for changing the PC Port and Web Access amongst other settings.
Under the Update Phone option when you select the phones you require changing by using either a query or customer file, you simply enable the checkbox by the setting and change the field accordingly from enable to disabled for example.
Allan.
paulhardy Mon, 12/10/2007 - 15:58
Thanks for the reply.
This is what I am doing.
Bulk Administration -->Phones-->Update Phones-->Query
*I then search for the phones I want to update and click next
I can then update the following sections
Device Information
Protocol Specific Information
External Data Locations Information (Leave blank to use default)
Extension Information
Certification Authority Proxy Function (CAPF) Information
MLPP Information
Secure Shell Information
Assign IP Phone Services
Job Information
I do not have access to
Product Specific Configuration Layout
which is where the web access and other settings are.
Any ideas.
Paul
guerrad Thu, 12/13/2007 - 10:49
Paul,
You will only have access to the Product Specific Configuration Layout, if all the devices within the Query results are the Same Type and Protocol, i.e. if you results returns 7940 SCCP 7940 SIP & 7960 SCCP, you will not be present the options for Product Specific Configuration Layout, as there is no common Product.
Hope that helps.
- Dave
paulhardy Thu, 12/13/2007 - 15:56
That makes sense. thanks. We do have a mixture of 7971 and 7941 phones.
paulhardy Mon, 12/10/2007 - 16:26
I have found a way. Ill share my findings
You cant update these through the query tool.
The way to do this is to create a csv file with the extesnions you want to update(or export the phones using the export BAT)
The you use the BAT Update phones using custom file . this way gives you the option to update these settings.
Hope this helps
Paul
allan.thomas Mon, 12/10/2007 - 16:33
Good to hear that you were able to work around the problem. The fact that you are not presented with the options to change the various device setting when using the query must be a bug and maybe worth raising with TAC if it causes you too many problems.
The reason is that on an earlier CCM release 5.0.x which I have in a lab, I certainly have the options to update these device settings.
Allan.
