Maximum number of devices to reset
Dec 10th, 2007
I have a question and have been unable to find any real definitive answer on. Is there a maximum number of devices to reset at one time? For instance, if I change my moh source in my common profile that has 1100 devices should I update all 1100 of them at the same time? I just dont want any devices as i reset them to be put is some sort of "limbo"
Thanks ahead of time for the replies.
Matt
Rajesh Revuru Mon, 12/10/2007 - 16:45
I am not sure if there is any limit on the devices that you can reset. If you are concerned, that you can reset based on either Device pool or device type, that way you are comfortable that you are not overwhelming the system
