connection problem with 7606
Dec 10th, 2007
Hi, I have a 7606 switch using GBIC fibre connection to the other site switch through SP. Both ports configuration are trunk mode,I can't ping the other site switch SVI from my SVI(both are on the same subnet and VLAN), but SP switch in the middle using SVI can ping our both sides,also I can ping the other site after I replace from 7606 to 2950 with same configuration.
7606 can recieve the arp from the other site switch, but the age is 0. The debug information shows it sent a arp without the opposite mac-address.
interface GigabitEthernet1/1
no ip address
switchport
switchport trunk allowed vlan 200
switchport mode trunk
interface Vlan200
ip address 192.168.1.100 255.255.255.0
I hope someone can help me.
smothuku Tue, 12/11/2007 - 00:37
  • Silver, 250 points or more
Hi Vidya ,
confirm me whether below one was exact setup or not.
7606 switch - SP Switch-- Site switch.
problem is you are not able to ping to site switch fro 7606 switch..if you replce 7606 with 2950 u r able to ping to site switch.
Can you paste the configs and connectivity b/n switches.
satish
vidyalv00 Tue, 12/11/2007 - 07:44
Hi satish,
The problem is I can only see my site switch (7606) which I already paste the configs upper, I can tell my site the configs is correct, and also according to the testing result I guess the opposite configs should be fine, and I can't understand why the SP switch in the middle one can use vlan 200 (SVI) ping both sites if we have the misconfigs on the opposite switch, even when I replaced the 2950 with same configs it can work. How can explain that ?
Yufeng
