12-10-2007 09:22 PM - edited 03-05-2019 07:55 PM
Can we define two DHCP servers IP in VLANS,whereas one chould act as primary and the other should work as secondary.
regds
Nasheer
12-10-2007 09:26 PM
yes nsaheer, u can do that
putting the same command with second ip addres
s in next line.
12-10-2007 09:55 PM
Hi Shiva,
Thanks for the reply.
Only giving the second IP address,is enough?
If the First IP address (Server) is down will it check the secondary IP address automatically or is there any commands need to be given ?
Overall can you pls tell me the process how it will switch over.
regds
12-10-2007 11:08 PM
Hi Nasheer
if you use 2 ip-helper addresses then the router will use both at the same time. The first DHCP server to respond is the offer that is forwarded onto the client.
So it is not a primary and secodary setup, both ip helper-addresses are equal.
Jon
12-10-2007 11:31 PM
Hi Jon,
So if both the servers are ON,It will check on both the servers and ip will be assigned using any of the server.
But i want Ips shud be assigned using the First helper address and if it fails it should assign with the other address.
Pls suggest any configuration changes need to be done in the Network side.
regds
12-10-2007 11:33 PM
Hi Nasheer
You can't do this as far as i know as the router will use both if you have 2.
What you can do is split your DHCP scope between the 2 DHCP servers so that either DHCP server will have available addresses for that particular subnet.
Jon
