cfajardo1_2 Tue, 12/18/2007 - 06:44
sorry for late reply..the CSS11500 supports firewall load balancing FWLB and in one of the mode, it seems like the firewall should support multinetting.(multiple ip address)
maratkinson Tue, 12/11/2007 - 13:12
Multinetting?
Sounds like you might be talking about ...
- VLSM variable-length subnet masking
- Classless Inter-Domain Routing (CIDR)
- routing prefix aggregation (also known as "supernetting" or "route summarization")
http://en.wikipedia.org/wiki/VLSM
Collin Clark Tue, 12/11/2007 - 13:18
  • Purple, 4500 points or more
Geez Adam I hope you knew that off the top of your head :-)
Celso, I have never tried it, but I'm pretty sure you can not assign multiple IP's to a single interface.
acomiskey Tue, 12/11/2007 - 13:25
  • Green, 3000 points or more
Haha, google is my friend.
JORGE RODRIGUEZ Tue, 12/11/2007 - 13:31
This is correct, however, the only way I see this possible looking Adam's link is if you were to used 802.1q and subinterfaces in ASA 7.x each sub with same security level.
Rgds
Jorge
Collin Clark Tue, 12/11/2007 - 13:46
OK, but what about routing? How can you control which interface the traffic leaves on? Assuming you care about that.
JORGE RODRIGUEZ Tue, 12/11/2007 - 14:22
What do you mean by routing? you can route between same security interfaces without issues, subinterfaces are routed interfaces are they not.. perhaps I don't understand you when you said " what about routing" ?
Rgds
Jorge
maratkinson Tue, 12/11/2007 - 13:42
Ahh ... yes, use multiple VLAN's to segment up a single interface. We have several ASA 5520's running that configuration.
Sample of such: Notice that you can assign different Security levels.
interface GigabitEthernet0/2
speed 1000
duplex full
nameif SUB-DMZ
security-level 60
no ip address
interface GigabitEthernet0/2.2114
description Citrix
vlan 2114
nameif SUB_Citrix
security-level 75
ip address 172.17.122.x 255.255.255.x
interface GigabitEthernet0/2.2126
description Secure Email Sub DMZ
vlan 2126
nameif SUB_SEC_EMAIL
security-level 75
ip address 172.17.123.x 255.255.255.x
JORGE RODRIGUEZ Tue, 12/11/2007 - 14:13
Marc, using your config and Adam's example link the scenario of multiple IPs per interface could be accomplished this way.
speed 1000
duplex full
nameif NET
security-level 75
no ip address
interface GigabitEthernet0/2.183
description Network 183.55.2.0
vlan 183
nameif NET183
security-level 75
ip address 183.55.2.77 255.255.255.0
interface GigabitEthernet0/2.204
description Network 204.238.7.0
vlan 204
nameif NET204
security-level 75
ip address 204.238.7.22 255.255.255.0
interface GigabitEthernet0/2.88
description Network 88.127.6.0
vlan 88
nameif NET88
security-level 75
ip address 88.127.6.209 255.255.255.0
use same-security-traffic permit inter-interface command to pass traffic between these nets without the use of ACLs.
