Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929602members
1244313discussions
Community Activity
Resolved! VLSM with Inter-VLAN routing
Hello,Studying for my CCNA and I thought I'd practice some basic configurations, such as router on a stick. I setup 4 PC's (each representing an imaginary number of hosts) each with a vlan attached to a switch leading to a router, with the link betwe...
Resolved! CISCO WSA upgrade alert error
We have upgraded our S1000v(wsa ) from 14.5.1 to 14.5.2 and upgrade was successful but when we checked the alerts we found an alerts as An application fault occurred: ('heimdall/svc.py send_command|195', "<class 'heimdall.exceptions.unknownprocess'="...
DK9 by Level 1
  • 103 Views
  • 7 replies
NTP and Syslog packets with specific IP Address
Hi All,I have a couple of C9300 L3 switches that are connecting to an ASA firewall. The NTP and the syslog server for the switches are located behind a firewall.When one of the switches request/send packets the gateway IP is the source address on the...
Ranjita by Level 1
  • 109 Views
  • 6 replies
Resolved! Why, when AP joins EWC, the AP gets an EWC image
Hi all,This is my first time working with EWC, and I'm a bit confused about the joining process of the access point.First, here are the hardware components I'm working with:Access Point: C9120AXE-EEWC: C9130AXE-EWC-EVersion: 17.9.4aI don't understand...
Shiden by Level 1
  • 1101 Views
  • 19 replies
Cisco 2500 Wireless Controller, limit bandwidth for WLANs
Hello!I need help, I have a problem with limiting the speed for connections on a guest network. I've already studied the manual several times, but I can't figure out if there are any such settings on the Cisco 2504 Wireless Controller, Product Versio...
Viktor-Y by Level 1
  • 6 Views
  • 0 replies
Resolved! Connecting CX Cloud to Meraki Dashboard
Was looking to setup Meraki dashboard as a source for input to CX Cloud.  Is any one using this?  How easy was it to set up?  Any risks or important keys to success?
Active accounts are being displayed as Inactive?
Can anyone explain why an active account would be listed as having an Inactive status? These are accounts with a recent logon and authentication including successful DUO pushes. It's making it difficult to track those accounts that are actually Inact...
EMJ by Level 1
  • 49 Views
  • 2 replies
Duo Desktop not recognized
Hello, I am using Cisco Anyconnect to connect to VPN. The system is using Duo Desktop for device health. It is already installed, running and all the checks are ok. However, I am getting this error message and not able to proceed: Install Duo Desktop...
Sh2024 by Level 1
  • 128 Views
  • 7 replies
SSM ON-Prem TACACS+ and Clearpass
Hi,I am trying to configure TACACS+ on our SSM On-Prem server so that I am able to login on the Webinterface with my AD user. The TACACS+ configuration is done in Clearpass. And the test in the configuration window on the SSM server was successful.Bu...
Counterdoc_0-1713516283437.png Counterdoc_1-1713516355075.png Counterdoc_2-1713516408976.png
Fan noise of 350x-24
Dear all,I just received a 350x-24. The fan is quite loud, but that isn't a problem as no one sits beside the rack.I just wondered if a noise of 49.2dB average is normal or if it is a indiaction for a hardware or config problem?The noise level was ju...
