redistribute ospf question
henrybb
In my lab,I don't know why 6.2.1.0/24 is redistributed into ospf 2,and 99.128.1.0/24 doesn't.
From cisco document:http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml. Cisco said "Note: The mechanics of route redistribution is proprietary on Cisco routers. The rules for redistribution on a Cisco router dictate that the redistributed route be present in the routing table. It is not sufficient that the route be present in the routing topology or database. "
And in my lab,these two static route is "static" in routing table,So why one can be redistributed via "redistribute ospf 1" and another doesn't ?
thanks!
230#sh run | b r o
router ospf 1
log-adjacency-changes
redistribute static subnets
network 6.0.0.0 0.127.255.255 area 0
router ospf 2
redistribute ospf 1 subnets
network 6.128.0.0 0.127.255.255 area 0
ip classless
ip route 6.2.1.0 255.255.255.0 Null0
ip route 99.128.1.0 255.255.255.0 Null0
230#sh ip ospf da
OSPF Router with ID (99.1.133.230) (Process ID 2)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
99.1.133.230 99.1.133.230 100 0x80000002 0x00C540 1
Type-5 AS External Link States
Link ID ADV Router Age Seq# Checksum Tag
6.1.1.0 99.1.133.230 100 0x80000001 0x002DAD 0
6.2.1.0 99.1.133.230 100 0x80000001 0x0021B8 0
OSPF Router with ID (99.129.1.1) (Process ID 1)
99.129.1.1 99.129.1.1 123 0x80000002 0x006FE9 1
6.2.1.0 99.129.1.1 122 0x80000001 0x00DED1 0
99.128.1.0 99.129.1.1 128 0x80000001 0x0033A1 0
230#sh ip route static
99.0.0.0/8 is variably subnetted, 16 subnets, 3 masks
S 99.128.1.0/24 is directly connected, Null0
6.0.0.0/24 is subnetted, 3 subnets
S 6.2.1.0 is directly connected, Null0
230#
mheusing
Your database output shows additional routers "99.1.133.230" and "99.129.1.1", who also could contribute to your puzzle.
Could you please provide the output of "show ip ospf database external", which should help to clarify the situation.
The puzzle for me is, why those static routes show up in OSPF 2 in the first place. "redistribute ospf 1" can be rephrased to "Redistribute everything inserted into the routing table by process OSPF 1". Both static routes should not be redistributed this way, as they are no OSPF routes.
So please provide the config of the other OSPF routers in your lab and the output from "show ip ospf database external".
regards, Martin
There isn't any other routers in my lab. "99.1.133.230" and "99.129.1.1" is the same router.
You puzzle is for me,too.
230#sh ip ospf da ex
LS age: 787
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 6.1.1.0 (External Network Number )
Advertising Router: 99.1.133.230
LS Seq Number: 80000021
Checksum: 0xECCD
Length: 36
Network Mask: /24
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 1
Forward Address: 0.0.0.0
External Route Tag: 0
LS age: 787
Link State ID: 6.2.1.0 (External Network Number )
Checksum: 0xE0D8
Length: 36
Network Mask: /24
TOS: 0
Metric: 1
LS age: 1353
Advertising Router: 99.129.1.1
Checksum: 0x9EF1
Length: 36
Network Mask: /24
TOS: 0
Metric: 20
LS age: 1354
Link State ID: 99.128.1.0 (External Network Number )
Checksum: 0xF2C1
Length: 36
Network Mask: /24
TOS: 0
Metric: 20
230# sh ip int brief
Ethernet0/0 99.1.64.230 YES NVRAM up up
Ethernet0/1 unassigned YES NVRAM administratively down down
Loopback0 99.1.133.230 YES NVRAM up up
Loopback1 99.129.1.1 YES NVRAM up up
Loopback3 6.1.1.1 YES NVRAM up up
Loopback4 6.128.1.1 YES NVRAM up up
230#
230#sh ip ospf nei
230#
regards
paul.matthews
Level 5
Level 5
This is an observation. I can't help but note:
router ospf 1
The route that makes it to OSPF 2 just happens to be a match to the network statement in OSPF 1. The network statement includes all interfaces having addresses from 6.0.0.0 to 6.128.255.255. I don't think that should have any relevance, but it strikes me as interesting with the difference between the two routes. I presume 99.1.133.230 is an interface address on the local router? Where is 99.129.1.1? again I suspect it is local, but it would be nice to confirm. I would be tempted fo force the OSPF router ID on the two processes for clarity. I would also be tempted to add another static that matched the network statement, just to see what hapenned.
thanks for your guide. It have relevance.
I think that "ip route ... interface" in CISCO is special static route. In my lab,6.2.1.0/24 is one route in OSPF 1 because CISCO think this route is connected route in OSPF 1 domain. So it was redistributed into OSPF 2.
If I change route from "null 0 " to ip address,for example:
ip route 6.2.1.0 255.255.255.0 99.128.1.3
This route wasn't redistributed to OSPF 2.
"ip route ... interface" is special route type.
When you do "redis connected",this type route wasn't redistributed .You must do "redis static".
So I don't know why CISCO do this, but it do.
Sometime this route is regarded as connected route when you redistribute between dynamic routing protocol or doesn't redistribute. Sometime it is regarded as static route if you redistribute from static to dynamic routing protocol.
I'm in puzzle.
thanks!
