VPN to DMZ
Answered Question
Dec 11th, 2007
I have a ASA5505 at the remote end (ip base) with a server in the DMZ. DMZ is 10.102.1.0/24 and LAN is 172.16.0.0/16.
I have created a site to site tunnel from our network and can connect to 172.16.0.0/16 fine. I have also added to the crypto map to pass 10.102.1.0/24 traffic down the tunnel. I have also permitted outside - inside traffic to the DMZ from my LAN subnet.
I still can't ping the DMZ from my LAN - is this possible or am I missing something?
Correct Answer by husycisco about 9 years 5 months ago
You should add conditional exempt nat rules
remote ASA
access-list dmz_nat0_outbound permit ip 10.102.1.0 255.255.255.0 yourlocallan netmask
nat (DMZ) 0 access-list dmz_nat0_outbound
your asa
access-list inside_nat0_outbound permit ip locallan netmask 172.16.0.0 255.255.0.0
access-list inside_nat0_outbound permit ip yourlocallan netmask 10.102.1.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
access-list outside_xxx_cryptomap permit ip locallan netmask 172.16.0.0 255.255.0.0
access-list outside_xxx_cryptomap permit ip locallan netmask 10.102.1.0 255.255.255.0
Overall Rating: 5 (1 ratings)
Correct Answer
husycisco Tue, 12/11/2007 - 02:20
  • Gold, 750 points or more
remote ASA
your asa
rasoftware Tue, 12/11/2007 - 02:27
thanks a lot - totally forgot about that step!
Many thanks
Rob
Jon Marshall Tue, 12/11/2007 - 02:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you just elaborate on the topology. When you say you can't ping the DMZ from your LAN is this the same LAN as 172.16.0.0/16 or is this the remote network.
Jon
