TFTP via tunnel
Dec 11th, 2007
Hi all,
I am trying to TFTP the running config off a ASA via a tunnel onto my LAN.
Can't remember the command for this. It's ip tftp source-interface Vlan1 on a router.
Can anyone help?
Overall Rating: 5 (1 ratings)
rasoftware Tue, 12/11/2007 - 05:12
Hi tried that, same issue
Paint-GW# copy running tftp://192.168.150.233
Source filename [running-config]?
Address or name of remote host [192.168.150.233]?
Destination filename [\]? paint-fw
Cryptochecksum: xxx
just times out
husycisco Tue, 12/11/2007 - 05:31
  • Gold, 750 points or more
what happens when you run following in ASA
ping 192.168.150.233
rasoftware Tue, 12/11/2007 - 05:32
fails - but can ping from behind the asa to the subnet.
husycisco Tue, 12/11/2007 - 05:40
can you post me the nat0 acl, the cryptomap acl and the firewall IP address?
acheron69 Tue, 02/19/2008 - 14:12
Any news on your TFTP via tunnel. I have the same issue.
davidecooper1967 Mon, 01/19/2009 - 14:58
You need to identify to the ASA the Address of the TFTP server to allow it
tftp-server inside X.X.X.X filename
filename being what you want to call the config file
then do this
copy running-config tftp:
Address or name of remote host [x.x.x.x]?
Destination filename [myfilename]?
Cryptochecksum: e0656519 1a702cac a9463a51 bb8d23bd
189404 bytes copied in 12.140 secs (15783 bytes/sec)
regards
David
