Voice-port command
peternnaji
I am trying to configure an FXO port on a router but the comand "voice-port" is not accepted. Is the command 'voice-port" supported on a cisco 2811 router?
allan.thomas
Level 8
Level 8
Further to my previous post, one aspect which I initially overlooked was that there are no PVDMs listed in the output of the 'show diag'.
For both the FXO modules you will initally require at least a single PVDM2-8 in order to support 8 G711 voice channels.
Allan.
6 Replies 6
allan.thomas
Level 8
Level 8
The command 'voice-port' is certainly supported on the 2811, it depends on the IOS which is running on the gateway.
In order to configure a specific FXO voice port, the correct syntax should be as follows:-
(config)#voice-port 0/1/0
(config-voiceport)#
Please advise which IOS version you have currently running on the gateway?
Incidentally, I assume that the voice-port is actually showing in the config? Can you confirm by posting the config and a 'show diag'.
Allan.
Hi Allan,
Thanks for your reply.
I tried the command as you specified, but it does not accept it. when I typed a questionmark after typing "voice" on global config mode, it only shows voice-card as option. The router IOS is c2800nm-ipvoicek9-mz.124-11.T4.bin. Attached are the outputs from the "sh run" and 'sh diag" command.
The version that you have specified should certainly support the VIC2-4FXO, the output from the 'show diag' indicates that the modules are recongnised, yet they do not appear within the configuration.
The earliest supported release is 12.4(2)T6, and the latest IPVoice-K9 release is 12.4(15)T1. I suspect that you running into a possible known bug, and unfortunately I cannot find any possible matches.
Therefore can I initally suggest that you upgrade to 12.4(15)T1 or later to see if the resolves the issue. I have configured a 2811 running 12.4(9)T3 with VIC2-4FXO in the past, so it is definately an IOS issue.
The AIM module incidentally is supported from 12.4(9)T6 within IPVoice-K9, therefore 12.4(15)T1 or later will fulfill your hardware requirement.
Hope this helps.
Allan.
allan.thomas
Level 8
Level 8
Allan.
Thanks a lot Allan. You've resolved my issue. I have installed the PVDM2-8 and I can now use the voiceport command.
Hi bro i met the same situation as you now.
I need your help from your experience...
Thx
