User authorization on CM6 via axl or something?
Dec 11th, 2007
Hi there!
I want to do a simple login form, which will be able to authorize user (input login or id and password) and then send to CM (I use Java) and get response, that this user is correct (and I can continue), or not.
Thanks in advance!
venca.balak Thu, 12/13/2007 - 04:08
SOLVED!
There is absolutely no problem, i just used axl:doAuthenticateUser(userid,password), which returns userAuthenticated as T/F
SOLVED!
