How to view date and time an interface was last up
Dec 11th, 2007
I am running a stack of Catalyst 3750's in a large office. I often find that ethernet ports are patched to desks that end up not being used for long periods of time. We end up with hardly any free switchports and it becomes a very manual job to find out which can be reused for another user. Is there a command I can use to view the date/time that each port was last up? This way I can see that a port has not been up for months and easily disconnect it for reuse.
Hi, I would use the "show ip interface brief" command it shows you the status of all the interfaces on your unit, if they are up and up, assigned IP or down down. You can also use the "show int fa0/1 | inc up" command on specific interfaces, also the "show int fa0/1 | inc minute" command will show you if any traffic has passed in the last 5 minutes.
floor1-sw1#show int fa0/1 | inc up
FastEthernet0/1 is up, line protocol is up (connected)
Half-duplex, 10Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
floor1-sw1#show int fa0/1 | inc minute
5 minute output rate 1000 bits/sec, 2 packets/sec
floor1-sw1#
glen.grant Tue, 12/11/2007 - 15:41
  • Purple, 4500 points or more
I am not sure why they don't build this into all their switches there seems to be a call for it . In the 4500 series there is a command but only for that series , it is "show interface link" and this will tell you how long the port has been down . Why they don't put this into all their gear is a puzzler...
davehedgehog Wed, 12/12/2007 - 01:27
I assume you have the 4500 series then. I'm no expert but I would assume you would always look at the input (ie frames from host to switch) but why they should differ by that much time I don't know.
So it's looking like there is no command in the IOS that can help me with this problem. That is a shame - it would be a useful feature on all switches.
