L2 MPLS (AToM) redundancy
arun kumar
Hi all,
Is it possible to provide redundancy for a L2 MPLS VPN Customer between his two sites. ( I thought of having a parallel pseudowire link and run any routing protocol between his CE's). Apart from this any other possibility of providing redundancy??
Thanks in advance....
swaroop.potdar
Level 7
Level 7
Arun, depending on your SLA to your customer you can choose the appropriate method for redundancy. The method which you have proposed if also fine.
Here is a feature called L2VPN pseudowire redundancy where in only one pseudowire would be active for the customer at a time just like what you have in opticals called protection circuits.
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080819eea.html
HTH-Cheers,
Swaroop
