guruprasadr Tue, 12/11/2007 - 05:30
HI Veena, [Pls RATE if HELPS]
Here is the sample configuration:
interface Multilink1
description *****MULTILINK in Mumbai*****
ip address x.x.x.x
ppp multilink
ppp multilink group 1
interface Serial0/3/0
description **CIR 1**
bandwidth 2048
ip address x.x.x.x
encapsulation ppp
ppp multilink
interface Serial0/3/1
description **CIR 2**
bandwidth 2048
ip address x.x.x.x
encapsulation ppp
ppp multilink
description *****MULTILINK in Chennai*****
ip address x.x.x.x
ppp multilink
bandwidth 2048
ip address x.x.x.x
encapsulation ppp
ppp multilink
bandwidth 2048
ip address x.x.x.x
encapsulation ppp
ppp multilink
PLS RATE if HELPS.
Best Regards,
Guru Prasad R
bvsnarayana03 Tue, 12/11/2007 - 06:57
Hi veena,
The 1st of concept of creating multilink is that the physical interfaces to be bundled in to multilink has to terminate on a single router at both ends.
hope that clarifies.
pls rate all helpful posts.
