2500 router freezes after power on.
I am reposting this question. There are a couple of typos in previous one.
I have a 2500 router. It freezes after it starts/reboots every time. I can't even get into its ROMMON, it won't respond to the key. I copied the message here. Thanks in advance.
Han,
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
2500 processor with 16384 Kbytes of main memory
F3: 9286440+846656+770252 at 0x3000060
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 2500 Software (C2500-IO-L), Version 12.2(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sat 31-Jul-04 03:32 by eaarmas
Image text-base: 0x03050A44, data-base: 0x00001000
cisco 2500 (68030) processor (revision A) with 16384K/2048K bytes of memory.
Processor board ID 01207578, with hardware revision 00000000
Bridging software.
X.25 software, Version 3.0.0.
1 Ethernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read ONLY)
Press RETURN to get started!
00:00:07: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface Serial0, changed state to up
00:00:08: %LINK-3-UPDOWN: Interface Serial1, changed state to down
00:00:09: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to up
00:00:18: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to down
00:00:20: %SYS-5-CONFIG_I: Configured from memory by console
00:00:21: %LINK-5-CHANGED: Interface Serial0, changed state to administratively
down
00:00:23: %LINK-5-CHANGED: Interface Serial1, changed state to administratively
down
00:00:23: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed state
to down
00:00:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state
to down
00:01:04: %SYS-5-RESTART: System restarted --
00:01:04: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold star
tˇ
FREEZES
Overall Rating: 4.5 (2 ratings)
Kevin Dorrell Tue, 12/11/2007 - 05:41
Couple of things to check. First, try re-seating the DRAM and flash modules.
Secondly, I presume you have tested your console terminal on another router. That is, I presume you terminal is working correctly.
Also, if your terminal is a laptop, try using a desktop PC instead. The voltages used by laptops on the serial port are sometimes not enough for reliable communication. The 2500 series seems to be particularly sensitive to incorrected levels on the serial line.
Kevin Dorrell
Luxembourg
ccbootcamp Tue, 12/11/2007 - 06:07
Change the flow control from hardware to software or vice versa. That seems to fix this issue. It's different serial chipsets on motherboards that causes this problem with older 2500s.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
