gre+ipsec for cisco 3750e, 4948, 6500
Answered Question
Dec 11th, 2007
Does cisco 3750e, 4948, 6500 switches support gre+ipsec ????
Correct Answer by Jon Marshall about 9 years 7 months ago
No problem, glad to be of help.
Jon
Correct Answer by Richard Burts about 9 years 7 months ago
Sai
I am pretty sure that neither the 3750E or 4948 support that. I was not so sure about the 6500 but when I look at the Feature Navigator and the Config Guide for the 6500 I do not see them as options for the 6500 either. So believe that the answer is that none of these platforms support gre+ipsec.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Tue, 12/11/2007 - 06:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sai
Rick
saimbt Tue, 12/11/2007 - 07:32
Rick,
Thank u for the reply...
once again i repeat " u r a rockstar"...
-Sai
Jon Marshall Tue, 12/11/2007 - 07:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Sai
Just to add that the 6500 can do IPSEC but you need an additional port adapter for it. Please see the attached sheet for service modules/adapters on 6500.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_relevant_interfaces_and_modules.html#aism
Jon
saimbt Tue, 12/11/2007 - 08:11
Hi Jon,
I got this page but i was wondering will this attract a enhanced IOS (added cost) as well that would support gre+ipsec??
-Sai.
Jon Marshall Tue, 12/11/2007 - 10:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
What IOS are you running at present ?
saimbt Tue, 12/11/2007 - 21:24
right now we have not purchased the switch. We are evaluating the options.
-Sai.
Jon Marshall Wed, 12/12/2007 - 00:18
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The IOS that comes with the Sup720 should support this adapter as long as you get the right release.
Attached is the software configuration guide for this port adpater, it supports both GRE & IPSEC and specifies the IOS requirements.
http://www.cisco.com/en/US/products/hw/switches/ps708/module_installation_and_configuration_guides_chapter09186a00805f37bf.html
One thing i would say is that 6500 switches and the modules are not cheap. If all you want is some switching capability and VPN accelearation i would look at the 2800/3800 ISR router's which support etherswitch cards which will give you switched ports, vlans etc.
Jon
saimbt Wed, 12/12/2007 - 00:34
Bulls eye... even I am advocating a ISR router but few people in my organization want the link on the 6500.
The ballpark figures for a module and IOS comes roughly for $43K
and a ISR would come for $10K
I will convenience my guys to go for a ISR.
Thanks for the efforts, it is appreciated.
-Sai.
Correct Answer
Jon Marshall Wed, 12/12/2007 - 00:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
