Basic ACE Design Question
Dec 11th, 2007
Hi All,
In the network layout below, does the ACE need to be setup in a routed mode to work? can it be also be setup in a bridged mode in this scenario?
Network Cloud <--> Firewall <--> ACE <--> Router <--> Server Farm.
Any refences would also be greatly appreciated.
Thanks in advance.
HH
Gilles Dufour Thu, 12/13/2007 - 09:11
you can always chose between routed or bridged mode. This is also true for your case.
Gilles.
nyr.hakeem-habeeb Thu, 12/27/2007 - 03:14
Hi Giles,
Thank you for your response.
I was under the impression that if redirection is being done at layer-2 (aka bridged mode) then server's need to be layer-2 adjacent with the Load-Balancer. Is this not applicable to the ACE?
I would greatly appreciate more clarity on this.
Thank you in advance.
Nayyar
Gilles Dufour Sat, 12/29/2007 - 06:32
you only need the server adjacent if you do transparent loadbalancing. Which means you do not nat the virtual ip to the server ip.
Instead the servers are configured with a loopback ip address the same as the vip on the loadbalancer.
You can always bridge between 2 vlans and this is possible in your case.
However, I don't see the need to insert a router between the ace module and the servers.
Can't you have the ace module inserted between the router and the servers ?
Or get it rid of the router and have the servers directly connected to the ACE vlan and using the firewall as gateway ?
Gilles.
