Content Switch software and
niall.doherty
Level 4
Level 4
Hi.
I have a question relating to Content switches software. The sofware code shipped was 08.10.1.06 and I upgraded to 07.50.3.03. The old s/w was then removed.
However when I do a 'show chassis flash' although the it has the correct software it still indicates 08.10.1.06 in the following places:
ALP-CVP-CS01# sh chassis flash
Configuration for CSS11501S-C-K9 G0:
Product Name: CSS11501S-C-K9 G0
SW Version: 07.50.3.03
Serial Number: XXXXXXXXXXX
Base Mac Address: XX-XX-XX-XX-XX-XX
Module Name - CSS501-SCM-INT
Operational - *08.10.1.06
Locked - 08.10.1.06
CSS501-SSL-C-INT
Locked - 08.10.1.06
** SSL-C(ompression) module not supported with this code version
My question is about the '08.10.1.06' that is showing up. Is this correct/ok or should their be '07.50.3.03' instead? If so what do I need to do?
Niall
Diego Vargas
Hi Niall,
If you do a "show version" the one really matters is the Version, do not be concern about Locked and Operational, this is expected behavior, so your CSS is actually running 7.50.303
Now let me tell you that what you did was not really an upgrade.
7.50.303 is a newer version than 8.10.106 but is on an older train, so actually it would be better that you move to 8.10.301 which is equivalent to the 7.50 code that you installed.
Two reasons for this:
1. The 7.50 train is not supported by engineering anymore, in other words they are not doing new releases.
2. You have a CSS-SS-C-INIT module (SSL with compression) which is not supported on versions older than 8.10, so you need to have a 8.10 or 8.20 code to support your SSL module.
Hope it helps!!
Diego Vargas
Hi Niall,
Hope it helps!!
Thanks for that!
Niall
