12-11-2007 07:39 AM - edited 03-03-2019 07:53 PM
Can i get IP Base K9 IOS for cisco 1601 series.
regds
12-11-2007 08:00 AM
Nasheer
I have checked the software download pages on CCO and I do not see any IP Base K9 images for the 1601 or the 1601R routers.
Rick
12-11-2007 08:12 PM
Hi Rick,
Thanks for the reply.
I want to configure ssh in that router.Current IOS is not supporting.Can you suggest me for which IOS shall i go to enable SSH.
regds
12-12-2007 07:56 AM
Nasheer
It was not clear in your post whether your router is a 1601 or a 1601R so I looked for 1601 images. You could use the IP PLUS IPSEC 56 feature set and it would support SSH. An image with this feature set would be c1600-k8sy-l.122-15.T16.bin and would require 10 MB of RAM to execute this code.
Rick
