debug crypto isakmp on ASA
Dec 11th, 2007
Folks,
I have an ASA and would like to see why my ipsec tunnel is not coming up.
I enable logging. and then type in "debug crypto isakmp", but see nothing, in old pix could, it was so easy to troubleshoot but with 7.x code is there a good command to see debug output?
Overall Rating: 3 (1 ratings)
husycisco Tue, 12/11/2007 - 11:31
  • Gold, 750 points or more
Hi Navin
try
debug crypto isakmp 50
Also using syslogs is really useful. You know ASDM has one built-in. Set the loggig level to notifications
JORGE RODRIGUEZ Tue, 12/11/2007 - 11:37
  • Green, 3000 points or more
if doing the debug from telnet session you need to enable terminal monitor, try this.
ciscoasa#terminal monitor
then use your debug , to disable it issue terminal no monitor
Jorge
rmaxson2@comcast.net Fri, 12/14/2007 - 12:34
Quick trick, since debug can run away on you making it hard to enter commands. do this enter the NO version of the command first then enter the command like.
no debug crypto isa
debug crypto isa
that way if it takes off all you do is hit up arrow once and return to end the command.
