6500: How to speed up ACLs TCAM programming?
Edison Ortiz Tue, 12/11/2007 - 08:29
  • Hall of Fame,
    Founding Member
"mls aclmerge odm optimizations" allows you to fit more ACLs into the limited numbers of entries in the TCAM.
Disabling this feature will limit the amount of hardware based ACLs you can enter in the switch.
I disagree the document just scratches the surface. It's very well detailed and addresses all the nuisances of implementing ACLs in the Cat6k.
