Error on Cisco 4006
Dec 11th, 2007
I'm seeing the following two errors in my CAT 4006 running 8.1.2, anyone know how to fix this without rebooting the switch?
2007 Dec 11 11:17:02 EST -05:00 %MGMT-2-SESSION_FAIL:Out of telnet processes. Try later.
2007 Dec 11 11:17:02 EST -05:00 %KERNEL-1-CREATEPROCESSFAILED:Error in creating process: Unavailable free stack; stack type: 2; Name: tnetproc
Edison Ortiz Tue, 12/11/2007 - 08:40
  • Hall of Fame,
    Founding Member
Your system is running out of processes, perhaps you have a memory leak.
Before rebooting contact TAC and issue a 'show tech-support' to capture vital information.
glen.grant Tue, 12/11/2007 - 09:08
  • Purple, 4500 points or more
A reload will probably fix it and if the code is really old upgrade that to new code.
nawas Tue, 12/11/2007 - 09:11
Thanks guys.Reload has fixed the problem but i think this was due to the security scanning.
Thanks for all the help.
