4506 switch ip access list based policy marking
Dec 11th, 2007
it does not work. this is what I have on L2 interface. ALs are classic IP extended access lists. Why doesn't it work? None of packets are marked
class-map match-any c5
match access-group name c5_1
match access-group name c5_2
class-map match-any c2
match access-group name c2_2
class-map match-any c3
match access-group name c3_1
match access-group name c3_2
class-map match-any c4
match access-group name c4_1
match access-group name c4_2
policy-map OUT
class c4
set ip precedence 4
class c3
set ip precedence 3
class c5
set ip precedence 5
class c2
set ip precedence 2
interface GigabitEthernet9/99
switchport access vlan 55
switchport mode access
service-policy output OUT
guruprasadr Tue, 12/11/2007 - 23:56
HI,
In some environment i have experienced in matching the Access-group "name" in the Class-map statements. ==> Failure
But it works when done with Access-group "index-number".
>> As per manual it should work but i doesn't work.
Is this your problem ?
Best Regards,
Guru Prasad R
