ICM 7.1.5 Log-out activity time not working
Dec 11th, 2007
Using ICM 7.1.5, CTIOS, IPIVR. System IPCC configuration in Enterprise environment. Duplexed system for redundancy.
After timer of 7200 - agents are not being automatically logged out. I reduced timer to 7000 - still won't work.
after many tries - if I bring it down to say, 180 - it works - but not long enough for a production environment.
Any thoughts? I can't figure out why it won't log the agents off.
sbilgi Tue, 12/18/2007 - 09:35
This can happen when the Agent Desktop Settings are not taking effect. You an probably remove these and try readding the same.
cherilynn1030 Fri, 12/21/2007 - 10:32
I am unsure of the last sentence... Delete, and rebuild the desktop settings?
david.macias Fri, 12/21/2007 - 13:22
Not at first, set one agent to the Default desk setting and save. Then change them to your actual desk setting and test.
dam
