Ravi Singh Thu, 09/12/2013 - 10:12
  • Cisco Employee,
Maximum number of appliances supported
—While  a single Cisco Secure ACS Remote Agent can provide services to many  Cisco Secure ACS Solution Engine appliances, support is limited to five  concurrent connections by the appliances served. For example, if you  have three appliances that are primary Cisco Secure ACSes and three  appliances that are secondary Cisco Secure ACSes used for failover  purposes only, the remote agent can provide services to all six  appliances and stay below the maximum of five concurrent connections.
Jatin Katyal Thu, 09/12/2013 - 18:13
  • Cisco Employee,
Well guys, that's not a question.
M-ko,
The user guide doesn't talk about maximum number of remote agent you can add on per ACS solution engine. Could you please explain me your requirement, may be we can help you indirectly with this question. I have seen customers using 3 remote agents on a single appliance. I don't think it would stop you to define remote agents entries on the network configuration page.
~BR
Jatin Katyal
**Do rate helpful posts**
