Security lab for CCSP and CCIE Security
Answered Question
Dec 11th, 2007
I want to build a home lab for CCSP but something that will continue to work for CCIE Security. I want as much equipment as possible but don't want to spend a fortune. Any suggestions?
Correct Answer by ccbootcamp about 9 years 2 months ago
I suggest getting a couple of 2500s, 2600s, and a 3560-8port at bare minimum. An IPS sensor, VPN concentrator, PIX515, and a couple of ASA's wouldnt hurt either. Although if budget is an issue, just get the PIX515 and run 7.2 code.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
Overall Rating: 5 (1 ratings)
Correct Answer
ccbootcamp Tue, 12/11/2007 - 11:56
-brad
www.ccbootcamp.com
