12-11-2007 11:13 AM - edited 03-11-2019 04:42 AM
I have an ASA 5510 with a webserver in the dmz that is accessible to the outside from it's public IP (thanks to some help here yesterday), but not to the inside interface. I think I'm setting up the static NAT incorrectly.
The public IP is xx.xx.184.88 and the real IP is 172.16.0.176. I would like to use the public to view it from the inside interface. How would I configure that?
Solved! Go to Solution.
12-11-2007 11:58 AM
Sure that would be fine. You should have something like...
static (inside,dmz) 10.39.239.0 10.39.239.0 netmask 255.255.255.0
12-11-2007 11:26 AM
static (dmz,inside) xx.xx.184.88 172.16.0.176 netmask 255.255.255.255
or
static (dmz,inside) tcp xx.xx.184.88 www 172.16.0.176 www netmask 255.255.255.255
Hope it helps.
12-11-2007 11:43 AM
That moved the problem. Now I'm getting a "305006 partmap translation creation failed for tcp src inside:10.39.239.107/2198 dst dmz:xx.xx.184.88"
Should I post the config? Thanks!
12-11-2007 11:58 AM
12-11-2007 12:10 PM
That fixed it, thanks!
