CCM PRI GW
Dec 11th, 2007
Hi all,
I currently have two completely hardware seperate phone systems, both running cisco ccm 4.2(3) with a publisher & subscriber server, the "New" phone system I built was completely created from scratch, due to many techincal and hardware reasons.
For my PRI gateways I run 6608 (use 2 of 8 t1 as PRI),
The issue is this: when im on my old(existing) phone system, I'm able to ping the PRI interface port without any problem.
But, when I did a test run of my new ccm system after hours, my new CCM could no longer ping the PRI ports. Only configuration adjustment made was this.
Original config line:
set port voice interface 4/7 dhcp disable 10.10.10.20 255.255.255.0 vlan 65 tftp 10.10.10.15 gateway 10.10.10.1
New config line:
set port voice interface 4/7 dhcp disable 10.10.10.20 255.255.255.0 vlan 65 tftp 10.10.10.96 gateway 10.10.10.1
Any advice on how to go about troublshooting this?
TIA.
Overall Rating: 2 (2 ratings)
allan.thomas Tue, 12/11/2007 - 13:47
Firstly does the port show as connected after you initiated the change? Check this by using the show port 4/7 command and look for the Cisco CallManager server's IP address.
Also have you tried resetting the module using the reset 4 command after the change?
Allan.
thisisshanky Tue, 12/11/2007 - 20:09
I would suggest even trying to disable the port and enable it back to see if you are able to get them registered. Also 6608 modules sometimes need a reset of the module (reset 5, where 6608 is in slot 5).
Sankar
PS: please remember to rate posts!@
fredj1234 Wed, 12/12/2007 - 10:07
I've tried everything you've suggested, even completely rebooting the switch had no effect.
My "old" ccm system was 4.2(3) once I patched it to 4.2(3)sr3, it had the same issue pinging the 6608 PRI interface LAN IP.
Reguardless, the phone system was installed and integrated successfully.
The PRI works fine too :) Just it eludes me as to why I can no longer ping.
Thanks for your responses.
