Question About HSRP With Four (4) 65xx's
dholder
Good afternoon,
I once found a document on how to configure HSRP for VLAN's going across four (4) 65xx's. We have about 4 VLAN's that span these 65xx's. We are implementing a WAN core containing two (2) 6506E's that will have a 10 gb connection to each of the 65xx's that will make up our server farm. I once found a document that gave examples, but cannot find it now. And any campus design doc that I have found, does not contain HSRP config. Any help would be appreciated.
Thanks in advance for you assistance.
Dave
Dave
No problem. Is it safe to assume that you have a L2 link between the 2 6500's that your servers are connected to.
If so i would stick with just running HSRP on the server 6500's and uplinking with L3 links to your core. This contain STP to the server 6500's.
Jon
6 Replies 6
Jon Marshall
Hi Dave
If all switch inreconnects are L2 trunks then you can just configure 4 SVI's for the same vlan in the same subnet, one on each 6500 and then configure the same Virtual IP under all 4 SVI interfaces.
Am i missing the point ?
Jon
Jon,
No you are not missing the point. You answered the way I asked. What I forgot to also ask, was would I connect the four (4) 65xx's together to allow HSRP hellos to talk? Or would that occur up the links going to the WAN core? I just want to make sure I don't have two (2) 65xx running in Primary for the same VLAN.
I hope I asked that right.
Dave
Dave
Could you describe the exact connectivity between the 4 6500's and whether the connections are L3 or L2 connections.
Just want to be sure i don't give you duff information.
Jon
Jon,
Sorry for not getting you all the information, as I forget some of these config issues.
I guess that is the question exact connectiviy between the 4 6500's. I had not planned to connect them. I am planning to run 10gig L3 connections from each 6500 up to the WAN core. So, each 6500 would have 2 10gig connections, and I guess your saying I might need a L2 connection between the 6500's.
Thanks for all the help.
Dave
Dave
Jon
Thanks for the assistance. That L2 link is what I forgot.
Have a great holiday.
