http access wont work
Dec 11th, 2007
hello newbie question
i am trying to access the web interface of a asa and i put the following commands
and it asks for a username and password
which is not defined on the asa
http server enable
http 172.17.14.138 255.255.255.255 inside
what else do i need?
my telnet and enable pass dont work
JORGE RODRIGUEZ Tue, 12/11/2007 - 13:42
did you try https:\\FW_ip_address ? when prompted with user name leave blank and enter enable password.
for telnet add in asa:
telnet 172.17.14.138 255.255.255.255 inside
Jorge
ggittins Tue, 12/11/2007 - 13:50
thanks that worked. what would be the command
to authenticate locally or to taacas
JORGE RODRIGUEZ Tue, 12/11/2007 - 14:30
Geroge, glad that worked..
to create user name locally use :
username Joe password xxxxx privilege 15
Jorge
Please rate post if resolved.
