NAT port 1433 (SQL) from dmz to inside server
mark.michini
Hi All,
I am new to the ASA and trying to set up NAT to allow a web server to access port 1433 on an inside sql server. I have been able to successfully use the static nat command to open port 80 and 443 from the outside interface to the dmz but can't seem to figure out dmz--> inside.
Trying to allow sql access from webserver to SQL box on inside network
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.0
interface Vlan3
nameif dmz
security-level 50
ip address 10.10.1.1 255.255.255.0
global (outside) 1 x.x.x.200-x.x.x.245 netmask 255.255.255.0
global (dmz) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
web server is 10.10.1.10
sql box 192.168.0.11
10.10.1.11 open address on dmz subnet
static (inside,dmz) 192.168.0.11 10.10.1.11 netmask 255.255.255.255
access-list DMZtoInside extended permit tcp host 10.10.1.10 host 10.10.1.11 eq 1433
access-group DMZtoInside in interface dmz
Any suggestion.
Thanks in advance
Zuke
5 Replies 5
JORGE RODRIGUEZ
Level 10
Level 10
You could change the static as:
static (inside,dmz) 192.168.0.11 192.168.0.11 netmask 255.255.255.255
ACL
access-list DMZtoInside permit tcp host 10.10.1.10 host 192.168.0.11 eq 1433
Jorge
Jorge Rodriguez
Hi Jorge,
Thanks for your response. That worked for allowing the server to access the 1433 port,
However, when I applied the access-group
the server 10.10.1.10 in the dmz could no longer perform an nslookup, e.g. no mail outbound
Log shows
4 Dec 12 2007 10:44:03 106023 10.10.1.10 66.93.87.2 Deny udp src dmz:10.10.1.10/1027 dst outside:66.93.87.2/53 by access-group "DMZtoInside" [0x0, 0x0]
Did I miss something.
Cheers - Zuke
where does your dns server seats, inside interface or outside?
Jorge Rodriguez
You want to do something like this...
access-list DMZtoInside deny ip any 192.168.0.0 255.255.255.0
access-list DMZtoInside permit ip any any
That worked.
Thanks for everyone's help.
Cheers - Zuke
