Location Appliance ...Getting started...
amjbmr808 Thu, 01/03/2008 - 13:22
I am having the same problem. Just curious what you had to-do to fix it?
Richard Atkin Fri, 01/04/2008 - 01:06
  • Silver, 250 points or more
At the risk of stating the obvious, have you read this configuration guide?
http://www.cisco.com/en/US/docs/wireless/location/2700/quick/guide/loc27icg.html
Generally, you (as an admin / user) do not directly access the 2700 / 2710, rather, you access WCS, and WCS then accesses the 27x0 for you as required. Communications between the WCS & 27x0 server generally just uses SNMP.
HTH,
Richard
larrywoods Thu, 01/24/2008 - 14:18
I have come across the same issue myself however, I can go through the configuration process no problem. I have 3 Cisco 2710 Location Appliances all running version 3.0 code. I got one to work no problem. I configured it, it reset, then I could connect it with WCS. Beautiful. However, the other two WILL NOT work for the life of me.
Basically, I get through the installation process and they reboot. I get back to the CLI after it reboots and log in. From there I do a "getserverinfo" and get the following message:
[[email protected]-Area4 root]# getserverinfo
com.aes.client.AesClientException: Request to server failed, reason: java.security.PrivilegedActionException: com.sun.xml.messaging.saaj.SOAPExceptionImpl: Message send failed
at com.aes.client.AesClientAdminImpl.getServerInfo(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.run(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
Ok, great, i know this means that the Location Appliance is NOT running for whatever reason. So (and I have been looking at the configuration documents posted online) I tried the following command to start the location:
[[email protected]-Area3 root]# /etc/init.d/locserverd start
Starting locserverd: [ OK ]
Ok, so it appears as if everything should be ok so I do another getserverinfo and get the same message again.
What do we need to do to get this running and what other trouble shooting methods are there so we can get this working?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
