idle timeout (regard to CSS11506)
Answered Question
Dec 11th, 2007
one of our service has problem:
on server site, there is warning messages same as below:
BEA-100089
Warning: The session id: sessionID has been accessed from currentServer, a server that is neither the primary (primaryServer) nor the secondary (secondaryServer). The request URL was: requestUrl
Description
The session id: sessionID has been accessed from currentServer, a server that is neither the primary (primaryServer) nor the secondary (secondaryServer). Repeated occurrences of this can cause memory problems and performance degredation, as sessions are loaded into memory on more than two servers at a time.
Cause
The most likely cause is a configuration error on a front end hardware loadbalancer or webserver plugin. They should be configured to respect the values of primary/secondary in the cookie (i.e., stickyness), when possible.
Action
Please ensure that the front end webserver or load-balancer has been properly configured.
I have been adviced that I need increase idle timeout.
but, I still do not understand this problem should increase idle timeout or stickness timeout?
if it is idle timeout, the server is 3 min, but, I looked CSS default, it only 8 second, so, do I cause any problem if I increase to 3 min?
If it is stickness inact timeout, server site has not document about it, how many I should set?
my configuration is:
content myservice-80
vip address 10.1.1.10
port 80
protocol tcp
balance leastconn
advanced-balance arrowpoint-cookie
add service myservice-myhost1-80
add service myservice-myhost2-80
active
ip address 10.2.2.11
protocol tcp
port 80
keepalive type http
keepalive uri "/webct/checkStatusForLb"
keepalive frequency 30
active
Any comments will be apprecaited
Thanks in advance
Correct Answer by Gilles Dufour about 9 years 2 months ago
you can increase the ilde timeout as much as you want.
The only thing you need to keep an eye on is the number of flows active on the box.
This number is limited.
So by increasing idle timeout you make flow stay longer in memory.
So, the command to use is a 'flow stats'
Check for free FCB.
Gilles.
use the command 'flow-timeout-multiplier 15' to bump the connection idle timeout to 15 x 16 = 240 sec ( 4min).
This is what is needed in your case.
Gilles.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Wed, 12/12/2007 - 02:57
Gilles.
julxu Wed, 12/12/2007 - 19:42
Hi Gilles,
many thanks for reply, and many thanks for previous replies. all of them very much help me.
Back to qustion:
since the prpoblem is port 80, and by my mistake, it is 180 mins (3 hours), so, I should add:
1350 x 8 = 10800 (3 hours)
I may have to monitor more close. could you please advice, how do I know if it causes me any problem? which command can be used to monitor this changes impact?
Many Regards
Correct Answer
Gilles Dufour Thu, 12/13/2007 - 02:02
Check for free FCB.
Gilles.
