guruprasadr Tue, 12/11/2007 - 23:51
  • Gold, 750 points or more
HI Aejaz, [Pls Rate if HELPS]
There is no seperate "shutdown" command to Power-OFF any CISCO Equipments nevertheless you can Reboot the Equipment.
If your requirement to Power-OFF means Physical Access to Equipment is needed but make sure before that Save all your Configuration.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
