upgrade fantray cat6506 with sup720 (urgent)
Answered Question
Dec 12th, 2007
For the upgrade of a catalyst 6506 i received a fantray with the name C6506-E-FAN can i use it in my cat6506 ?
Correct Answer by Jon Marshall about 9 years 1 month ago
I haven't got a 6500 with this setup but Cisco made sure that when they replaced the original chassis with the E-chassis you could still order the high speed fan trays for the 6500 chassis (FAN2). This suggests that an E-FAN is not compatible with the original chassis otherwise i'm not sure why they would continue to make them available.
See attached sheet for more details
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_eol_notice0900aecd8035ece4.html
Satish - do you have a 6500 with this setup ?
Jon
Overall Rating: 5 (1 ratings)
pbogaerts Wed, 12/12/2007 - 02:40
In this link it is not clear for me that you can use it, i must be 100% sure that i can put it in een WS-C6506.
Peter
pbogaerts Wed, 12/12/2007 - 02:45
Peter
Correct Answer
Jon Marshall Wed, 12/12/2007 - 03:12
Jon
Charles Dahlgren Wed, 01/16/2008 - 05:30
Hi!
I acctually have the excact same problem (6506 non E-chassi and an E-series fan tray) did you ever get any clarity regarding this?
Or does anyone else know?
Charlie
pbogaerts Wed, 01/16/2008 - 10:24
The "WS-C6K-6SLOT-FAN2" is the fantray for the catalyst 6506, you can not put a fan tray of the 6506E in the chassis of a 6506, the connection with the backplane is different (connector is not in the same place), also the kind of fan that is used is different in a 6506E 48V fan in the 6506 12V fan. The code for the fan tray of the 6506E is "WS-C6506-E-FAN" fan tray. Hope this help you.
Peter
