ASA Site to Site IPSec VPN question
george_daly
Hi all,
I have a question regarding IPSec site to site VPN.
There is an internal network, say 10.1.1.0/24 which NATs to global address 5.5.5.5 on the Outside interface. The remote network is 20.20.20.0/24
I want to NAT to the global address then send that over the tunnel.
Should the crypto map statement map the inside network 10.1.1.0/24 to the remote network 20.20.20.0/24 or should it map from the global NAT address 5.5.5.5?
Hope this is clear, thanks for any replies!
9 Replies 9
husycisco
Level 7
Level 7
Cryptomap should include the global address (NATed), not inside network in your case
access-list outside_100_cryptomap permit ip host 5.5.5.5 20.20.20.0 255.255.255.0
husycisco
Level 7
Level 7
Hi George
Feel free to ask dependent questions. For example how do you plan Conditional exempt NAT?
So I need to enable the option to allow communication between VPN peers connected to the same interface because this is an Outside to Outside tunnel?
Regarding the NAT - I already have exemptions specified from the internal network to the other internal address spaces through a NAT 0 access list if thats what you mean?
My typo, I didnt mean exempt. Here is what I mean
You have a nat statement like following
nat (inside) 1 0 0
global (outside) 1 interface
or
nat (inside) 1 10.1.1.0 255.255.255.0
Above statements wont let you NAT 10.1.1.0/24 to a 5.5.5.5 outside IP. You should have the following
access-list CNat permit ip 10.1.1.0 255.255.255.0 20.20.20.0 255.255.255.0
nat (inside) 1 access-list CNat
nat (inside) 2 0 0
global (outside) 1 5.5.5.5 255.255.255.255
global (outside) 2 interface
Make sure the statements in CNat and outside_100_cryptomap do not exist in your nat exempt rule
"So I need to enable the option to allow communication between VPN peers connected to the same interface because this is an Outside to Outside tunnel"
No. Your outside interface was peer for tunnel and still is. Your ASA outside to remote ASA outside. You should enable same security interface traffic, If you want to permit traffic from a VPN site, ends at outside interface, to a VPN site again which also ends at outside interface.
Thanks for your detailed reply, much appreciated.
I'm still not quite there, 10.1.1.0/24 doesn't NAT to 5.5.5.5 I think it just routes directly down the tunnel. This is the config I have currently:
access-list outside_cryptomap_20_1 permit ip host 5.5.5.5 20.20.20.0 255.255.255.0
access-list outside_nat0_inbound permit ip host 5.5.5.5 20.20.20.0 255.255.255.0
nat (inside) 0 access-list NONAT
nat (inside) 6 10.1.1.0 255.255.255.0
nat (outside) 0 access-list outside_nat0_inbound outside
global (outside) 6 5.5.5.5
In which access-list do I need to permit 10.1.1.0/24 20.20.20.0/24, or is an additional access-list required?
I am also in the same boat. I need to setup a site-to-site VPN connection to a vendor. Because of some addressing conflicts I need to both the hosts that reside on my network and the hosts on the remote side. Is this something that is doable or should I have the vendor do part of the natting.
Hi Paul
Just leave a post if you need assistance
George please post your running config
This config may prevent your internet access. So please post your config and let me advise
