ccbootcamp Wed, 12/12/2007 - 23:14
  • Gold, 750 points or more
have you tried doing a "write erase" and then "reload" ? That will definitely clear the config! If you are having issues getting into enabled mode, issue a break upon power-on (and seeing the DRAM in the router). change the config-register to 0x2142, and that will fire up the router with a blank config. Not sure exactly what you are trying to accomplish here, but maybe I guessed it.
-brad
www.ccbootcamp.com
(please rate the post if this helps!)
nunoalmeida2007 Thu, 12/13/2007 - 02:24
hi!
i accessed to console, but it havent those commands. do you know where can i found a bin file to upload, or other option?
NUNO
nunoalmeida2007 Thu, 12/13/2007 - 03:11
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Initializing Flash
Reading monitor variables from NVRAM
Finish Reading monitor variables from NVRAM.
Enabling interrupts
Enabling instruction cache
Reading cookie
Initializing main memory
Sizing NVRAM
Exiting init
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory
No bootable image file: flash:/
Unable to open boot file
This is want it get to me... can't open bootable image.
Help???
NUNO
ccbootcamp Thu, 12/13/2007 - 07:45
Your original post doesnt quite reflect the issue you are having. Sounds like you erased your FLASH as part of your "set the router to a default config" process! :)
You need to download an IOS image from TAC as your next step.
http://www.cisco.com/public/sw-center/index.shtml
-brad
http://www.ccbootcamp.com
ccbootcamp Thu, 12/13/2007 - 10:36
you're welcome, please rate my posts! :)
you'll have to get the IOS from cisco using a CCO account. that's the only legal way to get IOS.
-brad
www.ccbootcamp.com
