store the image.bin from flash to tftp server
Dec 12th, 2007
we have a pix 515e with pix version 7.22
and I want to store this binary file on a tftp server, but when I use the copy command 'copy flash tftp' I get an error message like 'Inappropriate file type or format'
oezkanuenlue Wed, 12/12/2007 - 05:05
I typed the command you have sent to me but I get the same error message.When I type 'dir'
at the prompt I see two files the first is the 'image.bin' and the second one is the 'downgrade.cfg'. So I want to save the image.bin to the tftp server with copy flash tftp command, but I get an error message which I desribed in my last message.
husycisco Wed, 12/12/2007 - 05:29
Oh, my bad. It is PIX 515 . You can not copy running image to a tftp. But you can copy the config file
oezkanuenlue Wed, 12/12/2007 - 05:58
butI think it must be possible to save the current image binary , we save it on a 515E with pix version 6.3 without problems
