CVP - say it smart error
Dec 12th, 2007
We have developed a CVP application which uses DTMF adapter & Say it smart plugin. However the error logs for the application report an error as below,
SAYITSMART Error - digits. This type does not support non numerical values. The value was "AAAAA999"
Has anyone faced this problem before.
janinegraves Wed, 02/06/2008 - 17:07
The Digits Say it Smart is only for digits, not alphanumerics.
Audium used to post a Spelling Say it Smart on their support forum that would do what you need. I'll attach the Java file, you'll need to compile it into a class file and then store the class file into the Studio and VXMLServer directory (see the CVP Programmer's Guide for Deploying custom code globally).
Good luck, Janine
