UCCX5.0 - How to disable unwanted subsystems?
Dec 12th, 2007
I have UCCX5.0 Premium w/ HA Option. In control centre, my nodes are in partial service because CRS engine is always in partial service. Reason being, there are four susbsytems that not in use.
Database Subsystem
eMail Subsystem
MRCP ASR Subsystem
MRCP TTS Subsystem
Since I am not using these features, can I disable them? It is not impacting anything anyway. Just that, the nodes are always in partial service. If I disable, then nodes will be always in full service. Thanks
Sunil Maruvada
Riccardo Bua Thu, 12/13/2007 - 08:07
Hi Sunil,
you get this subsystems since the Premium license is allowing them to be deployed.
You could use control center, subsystem properties to disable them.
There are no side effects for it.
Riccardo
smaruvada Thu, 12/13/2007 - 10:11
Riccardo,
Thanks for your reply. I tried to look for properties option and could not find anything under Control Center. Would you mind sharing the exact steps required to disable the unwatned features. I am not using DB, eMail, ASR & TTS features at this point. Thanks
Sunil Maruvada
Riccardo Bua Tue, 12/18/2007 - 09:35
Sincere aplogies Sunil,
the option I was thinking of is no more available since IPCCX 4.0.4.
You could enable or disable features on a node using the serviceability tools, just check a node and you will see what you could enable and disable and the mentioned are not there.
There is an outstanding feature request, CSCsf96864 to do what you are asking, but the fix is not committed yet.
Riccardo
smaruvada Tue, 12/18/2007 - 09:43
No problem at all.
Thanks for confirming it. I looked at all possible places and could not find anything.
Thanks again for answering my question.
:)S
Riccardo Bua Mon, 12/24/2007 - 09:19
Hi Sunil,
some good news ;-)
I followed up with the Engineering Group, the DDTS fix will be in 7.0, they are looking to port it back to all the newer version of outstanding releases.
This might mean that if you check in the newer Release Note for a newer Service Release of your version you might see a fix soon.
Riccardo
abrenes26 Mon, 06/09/2008 - 10:26
how can I activated MRCP TTS Subsystem?
do I need another server, or this service is preinstalled in the IPCC Premium
abcronin Wed, 02/11/2009 - 13:22
Hi All
I have this issue with a customer running UCCX 5.0.
Does anyone know if it is resolved or a workaround yet?
Cheers
Andy
abrenes26 Wed, 02/11/2009 - 14:24
Hi abcronin
you are having this problem because there is no possibility to disable this subsystems in order to see a clear "In Service"
Seems to be a bug.
